Hi
my 1999 Boxster 2.5 L only fires on Bank 1 after engine overhaul. Electrical connections on Bank 2 seem all good, and the injectors work too (found unburnt fuel in the exhaust manifold).
I had installed the camshafts exactly as per workshop manual and turned the engine many times to ensure that the markings stay aligned. But now I observe at least once cycle where
all inlet valves are closed, which clearly should not be. Re-reading the workshop manual 15-20 I am now unclear if a full rotation is needed between adjusting each Bank, or not.
Grateful for any advice. See pictures below, showing the camshaft markings in TDC front (F) and rear (R). Thanks!
