Old 04-11-2023, 05:13 AM   #1
RedTele58
RedTele58's Avatar
There's two Phillips screws. One is lower and most likely the head is kind of hidden down in the carpet. Feel around and you'll find it. It's towards the back and a few inches above where the bottom of the piece sits against the floor carpet.
The second screw is on top and hidden a bit by the convertible top mechanisms. It's on the top plastic piece. Oops! Like Jon says below - it's an 8mm bolt - not a screw. It's been awhile since I've dug around on one.
Once you have them removed, just lift up a bit on the carpet piece you want to remove. There's a couple of little clips that hold everything in place.
Search around - you'll find them both.
