Old 04-03-2023, 03:43 PM   #1
Tomikaze
Porschephile
Tomikaze's Avatar
I’m trying to remove it to change the gear oil. I’m also in the middle of upgrading to coilovers and need to disconnect the rear axles. I would leave it alone if I didn’t need to remove it.
The type of bolt used in this application is unimportant as the plate is under tension, not compression. I'd leave them alone.
2004 Porsche Boxster S
Portland, Maine
Tomikaze is offline   Reply With Quote
