Old 04-01-2023, 01:23 AM   #4
Hello.AmeerM
Hello.AmeerM's Avatar
Depending on the MY of your car, if your car is running RoW dme programming, which I assume it is because of your use of MOT, your secondary O2 sensors should already be ignored by the DME. Therefore decatting should not throw a code.
Can you start the car without pressing down on the clutch? If so, you're most likely RoW
Hello.AmeerM is offline   Reply With Quote
