Old 03-30-2023, 07:41 AM   #3
vkmotorsports
vkmotorsports's Avatar
The best way to isolate a leak is to first clean the area thoroughly, then add a UV dye to the oil. Run the car for a day ot two, then look at the area with an ultraviolet light source; the leak will light up like Christmas.......
1) Is there a brand of dye you recommend ?
2) once I add the dye and find the leak, do I need to do another oil change since the oil now has dye in it and may damage the engine ? ?
Greyish 2001 Boxster S
vkmotorsports is offline   Reply With Quote
