Old 03-26-2023, 02:26 PM   #1
ecp
The water issue:
I was more wondering if things got wet around the base of the gas pedal.
That is where the e-gas (potentiometer) is.
try recalibrating the throttle see if it has any effect.
And or disconnect the battery for an hour or so and see if the ECU will reset with default values.
5v is usually reference voltage .....the signal voltage from the ECU.
Never water up there. I thought it was up under the dash? Since it’s drive by wire, unless there’s multiple. The pedal feel is definitely different, I’m going to try that and also unplugging the pedal to see what readings I get.
ecp is offline   Reply With Quote
