Old 11-09-2006, 04:07 PM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by blinkwatt
If you are talking about the plastic pieces that is right next the actually door handle then you would have to look under it,there should be a small area where you can pry something(small flathead) to pop it right off.
Nice! ok ill do that, Do i have to pull the lever down then pry off the plastic peice?
Any idea how to remove the blade from the interior side vents?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
