You can scratch any ceramic coating. Sonax CC36 or Avalon King are great 3 year protection coatings. The more expensive, thicker coatings are more prone to scratching, not to mention some require heat lamps to cure. The only way to then remove that coating is to use a compound. Good luck!!
