Old 03-13-2023, 06:34 AM   #1
jaimster
sorry for not describing clearly what I m dealing with :
one of the issue - lost connection to the temperature coolant sensor . ( temperature gauge light flashing )
for some reason or you tube video
I thought it would be underneath the intake , so I started disconnecting / unbolting the intake ran into the NOT been able to just pull that out due to hose running across the bottom of the intake base
turns out all the work was not needed like I said sensor is located underneath the engine - replaced sensor ( just need to fix the plug ) .
original issue - car has HARD START ..hopefully the new coolant sensor would solve that issue and the start can start with issues
I assembled everything back together yesterday was never able to figure out how to pull that driver side intake so I just used old gasket ..
QUESTION REMAINS : procedure to remove the intake in case I ever need to do it . I have service manual from BENTLY however have not been able to find a procedure on that
do you remove the fuel injector rails first ????
jaimster is offline   Reply With Quote
