Old 03-11-2023, 08:00 AM   #11
Starter986
1998 Boxster Silver/Red
Originally Posted by GRS from Kzoo View Post
I'm having the same brake light problem with my 1998 Boxster 986, no brake lights at all, left right or center. All fuses check OK as do the front side marker lights. I bought a new Porsche brake switch from Pelican and replaced it and still nothing. I've also removed the (left side) taillight assembly and all of the bulbs on it are fine.
Is the taillight assembly what you are referring to as the "light bar"? What do you mean by adjusting the angle of the contacts? Right now I'm pretty stuck.
Yes... in the trunk... you have the harness that plugs into the bar. Remove the bar. You'll see the "circuit"(s). Inspect and make sure the metal of each contact is, well, making the proper contact. You can have the accessories powered up (key on)... and start plugging and playing until you find the anomaly.
Also... check my post #4 above.
1998 Porsche Boxster
