Old 03-10-2023, 04:25 PM   #5
blue62
Originally Posted by wiebuschk View Post
I also have a bit of an surging idle issue. This really seems like vacuum leak.I likely disturbed something while cleaning the TB. If I spray starter fluid in the vicinity of the Y connector and vacuum tank I get a slight rpm surge. This is foreign land to me. What breaks or splits in that area?
could be the Y connector
Could be one of the hoses
Could be the vacuum canister.
If there is a one way check valve it could be the check valve.
With your surging idle.
Run your RPM up to 2500-3000 RPM and hold it there for say 20-30 seconds.
If the engine smooths out and runs normal then it is very possible that it is a vacuum leak.
If it will not smooth out and run normal or very near normal then it is something other then a vacuum leak.
Do the above test with a fully warmed up engine.
