Old 03-10-2023, 08:57 AM   #2
blue62
Originally Posted by wiebuschk View Post
I am getting lots of oil smoke at startup but it is intermittent. This was not a problem before I cleaned my throttle body. I am reading that the AOS is a likely culprit and should almost be changed as maintenance so I have ordered one. It looks like Pelican has some special clamps to make the job easier. What else should I look at or order? Can the AOS cause this but not everytime? Vacuum on the oil filler feels very normal.
To "feel" vacuum at the oil filer is not at all an accurate way to diagnose an AOS issue.
You need a proper gauge to test the vacuum. Do a search here on the forum you should be able to find some threads on the issue. They should show a picture of a gauge and the testing spec.
