Old 03-08-2023, 03:15 PM   #7
blue62
Originally Posted by sfkjeld View Post
Thank you. I hadn’t thought of that. Where is the “presta valve” and the fuel rail? And once I’ve pressed the valve, do I need to do anything to re-enable the fuel supply?
Look at the engine the fuel rail feeds the fuel injectors. If you know anything about engines you can't miss it. The presta valve is in the fuel rail it typically has a brass cap or plug over it.
When you replace the fuel pump relay or fuse and go to restart the engine for the first time just turn the key to the on position a wait a few seconds and give the fuel pump a chance to re-pressurize the system before engaging the starter.
