Old 03-08-2023, 01:49 PM   #2
blue62
Originally Posted by sfkjeld View Post
Thanks, but it sounds messy. Is there a fuse in the ignition circuit?
There is a "presta" valve on the fuel rail, It's like a valve on your tires.
push it with a screw driver while holding a rag over it.... done.
JFP gave you sound advice..... if you crank the engine over without disabling the fuel system and relieving the fuel pressure your going to be putting raw fuel into the engine....... washing the oil off the cylinders and bearings...... Not good for the engine.......
Then pumping raw fuel into the exhaust and possibly damaging the catalytic converters.
If you want to know the location or type of specific fuses or relays they are listed in the Bentley book.
I believe fuel injectors and ignition are the same fuse.
