Old 03-07-2023, 01:01 PM   #24
Radman
Your codes are showing that three of the four sensors are having issues.
I would replace all four with Bosch.
Then You have a solid foundation to work from.
An O2sensor and its wiring can be tested with a simple Digital Multi Meter.
Or the signal can be viewed with your Durametric.
If you switch the senor around looking to see if the code follows you have to move
two sensors then take the car for a drive sometimes multiple drives before the code shows up.
Senseless... when you can test them with a multi meter or Durametric in just a few minutes.
You must like spending my money lol! All 4 arrive friday.
Radman is offline   Reply With Quote
