Old 02-28-2023, 11:10 AM   #9
blue62
Originally Posted by ellie View Post
What is #20??
My guess is that it is a piece of rubber tubing.
It allows you to connect the hard plastic hose to the hard plastic nipple on the vacuum canister.
If you look at # 19 in the diagram it looks the same.
Then look at the first picture in the first post. You can see #19 just below his thumb.
Bit of rubber tubing connecting a hard three way connector to a one way check valve.
blue62 is offline   Reply With Quote
