Old 02-22-2023, 08:32 PM   #1
cheetahmoon
Cabin temperature sensor
Help appreciated. The cabin heater only blows cold, or hot when set to high. It seems likely that the cabin temperature sensor has gone. This is located behind the passenger heater vent on the dash. The unit, part number 99665324100 is a fan and some wire which I assume is the sensor. The fan works ok. A new part is very expensive, £300! Does anyone know if these can be fixed or substituted with an alternative part number? It seems to be a common problem, and expensive to fix so ideas welcome….
cheetahmoon is offline   Reply With Quote
