Old 02-13-2023, 08:53 AM   #1
JFP in PA
Originally Posted by Bush Pilot View Post
Thank you but I believe that a fault like that wouldn’t show up as an intermittent brown out. Also, the car is an Arizona car and all those connections appear as new.
Don't bet on it. The corrosion issue is internal to the cable, not just at the connections. Porsche has a TSB about it and improved replacement cables because of it. And a voltage drop test only takes about 10 seconds to run.
