Old 02-13-2023, 05:51 AM   #11
Frodo
Originally Posted by bobaachaar View Post
didn't specify, the brass one is the new one that he put in. don't think it's OEM but the impeller is a more durable material.
Careful what you wish for..
Common wisdom around here is that "more durable" impeller fins end up chewing away at things you don't want chewed up if/when the pump eventually fails. Recommendations seem to be to avoid them. Should be functional, I would think, but this is probably an item you'd want to preventatively replace before it even thinks about failing..
