Old 02-12-2023, 06:38 PM   #6
986tate
986tate's Avatar
if your dampers are height-adjustable then no such thing as rake as you would corner balance instead which would set the height of the four corners relative to each other.
Rake is an important thing to get right, are you confusing it with cross weight?
Checked my car, @131mm f/r, my front LCA is at 0 degrees and the rear is 5 degrees in the desired direction. (Rear mounting points are higher). I don’t have issues with tire shoulders wear or push.
986tate is offline   Reply With Quote
