Originally Posted by secreTTasianman
What is the best way to affix an emblem on the steering wheel? Thanks in advance.
Hi,
Are you replacing a wheel crest or adding one to the 4-spoke wheel? If replacing, you need to disassemble the airbag unit and grind off the rivet affixing the crest to the wheel, somewhat complicated procedure.
If adding one, the best thing is to use an adhesive like Liquid Nails after thoroughly cleaning the contact area with alcohol. Using double-sided tape will work, but usually make the crest stand too proud of the airbag, and double-sided tape may not afford the best adhesion. Hope this helps...
Happy Motoring!... Jim'99
