Old 01-25-2023, 05:46 PM   #2
Homeoboxter
This is what I suspect - the clutch switch for the non-start. I seem to recall that you had a brake light issue a while ago, but I don't remember how that resolved.
Check the clutch switch to ground connection, then put a jumper in place of the switch if the ground is good.
Yep. He actually says the brake lights don`t work in the first post, must be something at the pedal area. Or not
Homeoboxter is online now   Reply With Quote
