Old 01-23-2023, 05:20 PM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Could it be some bad ground connector around the pedals that makes the brake lights and the clutch switch both faulty?
This is what I suspect - the clutch switch for the non-start. I seem to recall that you had a brake light issue a while ago, but I don't remember how that resolved.
Check the clutch switch to ground connection, then put a jumper in place of the switch if the ground is good.
