Old 01-17-2023, 11:59 AM   #2
JFP in PA
Originally Posted by 1947verns View Post
My 1998 Boxster is burning coolant and in the process of removing the sparkplugs, coolant drained from the number 6 cylinder. I would like to take a endoscope video of the cylinder fully open to determine if the block or cylinder head is cracked. I need to rotate the crank shaft to the fully open position on this cylinder, but the crank shaft is not turning when a socket wrench is applied to the crank shaft. How can the crank shaft be freed up? Please advise. Thanks.
By spending a lot of $.
