Old 01-13-2023, 10:44 AM   #2
Keithbickford
Smile
Originally Posted by blueflames View Post
I fixed it. Fuse E6 was blown. This circuit is used for both the evap system fueling valve and the "telephony" system. There is a connector in the center console that shorts to ground and blows the fuse. This was my problem. I had been working in the center console in prep for installing a double din head unit. There was a TSB back in the 2000s that called for tapping up the end of this connection. I did this, replaced the fuse, and boom I was able to gas up.
Thanks!! This exact same thing happened to me. I replaced my radio and could not fill the tank the next time.
Keithbickford is offline   Reply With Quote
