Old 01-09-2023, 06:33 PM   #13
Homeoboxter
I am going to suggest a little pump of the brakes here. If you see a low pressure oil light and HEAR metal clanging then installing a gauge to verify what you hear is only further risking damage unnecessarily. This all started happening after an oil change and installation of a filter adapter, none of which should cause the symptoms you are seeing.
I would highly recommend dropping the pan. Something clogging the oil pickup screen such as some foil from an oil container, could cause these symptoms. The clogged screen would also cause the oil pump to cavitate which may have caused the leak.
Agreed. If the oil light illumination accompanies with engine clanking there`s no need to test its function, or at least it`s not top priority. You can easily cause permanent damage to the engine running it at low pressure.
