Old 12-30-2022, 06:11 AM   #15
Starter986
1998 Boxster Silver/Red
Originally Posted by seningen View Post
Trick here is to go get some bolts that are the same size of the tranny to engine and cut the heads off and slot them.
Use them as guides pins -- once you have everything aligned and the clutch happy -- you put the rest of the bolts in -- and then back these out with a screw driver and replace them with the actual bolts.
Mike
That. I used that method when pulling my oil pan (so many bolts). RTV is the sealant. Not wanting to have to remove any smeared sealant then squeezing out more sealant I purchased four bolts... cut off the heads as you described... notched them with a Dremel tool... one bolt in each "corner" of the pan... then aligning the oil pan with the bolts so it went straight up. I purchased two?three? inch bolts so there was some wiggle room.
1998 Porsche Boxster
