Old 12-09-2022, 10:15 AM   #4
JFP in PA
JFP... is that for specific years?
I swapped out my 4-spoke for a 3-spoke on my 98, having disconnected the battery beforehand. No lights, No hiccups.
Was I lucky? The reason I ask is because when I installed the 3-spoke... I did so a couple of splines off... rendering the steering wheel not perfectly straight when driving. If I remove and reinstall the steering wheel... should I be concerned about needing to have the SRS coded?
Thank you.
Changing a air bag, or steering wheel, does not impact the air bag control module, but the control module itself MUST be coded to the car, which requires the PIWIS.
