Old 12-09-2022, 09:51 AM   #3
Starter986
1998 Boxster Silver/Red
Yes, the airbag module has to be coded to the car, which requires a PIWIS system. A used one MAY be able to be coded, but that is not a guarantee.
JFP... is that for specific years?
I swapped out my 4-spoke for a 3-spoke on my 98, having disconnected the battery beforehand. No lights, No hiccups.
Was I lucky? The reason I ask is because when I installed the 3-spoke... I did so a couple of splines off... rendering the steering wheel not perfectly straight when driving. If I remove and reinstall the steering wheel... should I be concerned about needing to have the SRS coded?
Thank you.
1998 Porsche Boxster
