Old 12-04-2022, 01:52 PM   #2
elgyqc
elgyqc's Avatar
I had (have) the same situation, but my window drops just enough to clear the top with a hairs width of clearance. It never dropped as much as it should since I installed a cheap regulator a couple of years ago. When it started catching on the top last year I took up the slack in the cable with a spacer that is wider than a zip tie (forget what I used) and since then it is OK, as mentioned above.
Grant
