Old 12-03-2022, 07:15 PM   #3
elgyqc
elgyqc's Avatar
Are you talking about the starter or the alternator?
I've removed both from my 98... and the intake manifold remained in place. Now... for the starter on the 98 I did remove the throttle body and, if correctly I remember, did so to remove the alternator (for easier bolt access).
Starter. As mentioned I have changed a starter with the engine in the car. This time with the engine out I couldn't push the starter far enough towards the front of the engine to get the pinion out of the hole in the block that the starter sits in. That inch difference in length made the difference. If I can put the shorter starter in I would prefer that just in case it has to come out someday once the engine is back in the car.
Grant
