Did you try cleaning the "positive" ground? I chased a non-responsive key issue for quite a while and it was just a rusty connector. Make sure you disconnect the battery because this is directly connected to the positive terminal of the battery.
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
