Old 11-28-2022, 05:53 PM   #4
78F350
Motorist & Coffee Drinker
78F350's Avatar
Regarding the cross-over tube with the flapper valve, if you are running the car on your stock DME from the 2.5L, you can either leave the valve closed or force it to stay open after removing the vacuum hose that controls it. I think that closed is the better option. Here's a post I did back in 2015 that discusses the function of that valve:
Try looking up 'resonance flapper valve' for more info.
I think that any air going in or out of that hole is negligible unless you have excessive wear.
Quoted from: http://press.porsche.com/archive/products/press_kits/press_kits_2001/PDF/Boxster_in_Depth.pdf
"The Boxster inherits its twin-resonance air induction system from the 911
Carrera. The system acts as a “resonance supercharger,” allowing the engine
to draw from higher velocity airflow at certain engine speeds. A crossover pipe
connects the individual air collector/resonance chambers for each cylinder bank.
A flap in the pipe remains closed from idle to about 3,100 rpm. When it opens,
each cylinder bank can draw from airflow “excited” by the resonance created by
alternating induction between all six cylinders. In essence, “dual resonance”
creates two induction paths for each cylinder. Below 3,000 rpm, the cylinders
draw air from a “short” path. From 3,000 rpm to about 5,100 rpm – when the
resonance flap opens – the cylinders draw from a long intake path, which
boosts torque. Above 5,100 rpm, the flap again closes to allow the cylinders
to draw intake air from a shorter intake path to boost horsepower at higher
engine speeds."
