Old 11-22-2022, 12:58 AM   #1
chromecarz00
Originally Posted by elav View Post
Yes, there is a spring assembly by the pivot point for the clutch pedal. I tried lithium grease and it didn't work so I ordered a new assembly. I'm not sure what you mean when you say you have a noise from forward gears/3rd gear - do you mean the shifter is squeaking? If original, nearly all of the shifter parts are plastic...
You know I was pressing the pedal today with the car off and there's no squeak anymore. I wonder if something in the pressure plate was off. I'm going to leave the clutch spring for now and address post clutch - I am assuming that the spring is completely seperate.
Yes, regarding the shifter it's squeaking in forward gears and after pulling back the shifter boot it's all pretty dirty, grimy and has a half inch of slop. I'm guessing it's time for a shifter replacement soon and hopefully that will address. Is there any procedure to grease the lines or anything like that I should be doing on the clutch sidE?
chromecarz00 is offline   Reply With Quote
