Old 11-22-2022, 12:56 AM   #3
chromecarz00
Originally Posted by elav View Post
I did 986S swaybars - here is the parts list - CB-Racing, 986 Suspension Info
This is fantastic, thanks. You note that On the Boxster the anti sway bars are the same from USA to ROW - does this mean that the base will be the same as base, and S will be the same as S?
If I was to go from my base to an upgraded one and wanted to get poly bushings to match, I would just have to pull the correct size from this chart, yes? Any other parts needed (special drop links or standard will do?)
chromecarz00 is offline   Reply With Quote
