Old 10-24-2022, 06:01 PM   #1
jarjar
Yes, ideally all codes will be cleared eventually...I have the LEDs for the cluster just need to find time to solder them in
The car is a 2001 2.7 986
No other fault codes except airbag passenger side and AC codes and a seat buckle
I verified that the DME and fuel pump relays both work.
Jumpered the fuel pump relay socket and could hear the fuel pump...cant hear the pump with the relay in
Measured the voltage at the fuel pump relay socket and is only around 8V with the ignition turned on....should be 12V I believe to actuate the relay
Fuel pump fuse is good...measures 12.5 V on bottom side and OV on top side when fuse removed
I agree there is likely a ground issue somewhere...just have to find it...open to suggestions
cheers
jarjar is offline   Reply With Quote
