Old 10-24-2022, 12:56 PM   #1
blue62
Originally Posted by jarjar View Post
Thanks for the replies.
I tried to get the car to recreate the issue by idling it in the driveway...now it will stall on occasion...every 15-20 minutes or so...but will start easily after it stalls
My CEL doesn't work as I believe the LED is non functional in my cluster
Only code I can see of any import is a DME code 9110...K21 instrument cluster DME control unit
Intermittent issues are the hardest to troubleshoot...going to test DME and fuel pump relays when the rain stops
Cheers!
You may want to fix your CEL issue and your 9110 code issue first.
Instrument cluster issues can causes other issues.
Instrument cluster issues are often caused by low voltage (bad ground) issues.
You could wind up chasing your tail for a very long time with instrument cluster issues and codes present.
Always fix code issues and other known issues first.
Do you have other codes besides the 9110???
What year is the car??
