Old 10-24-2022, 07:56 AM   #1
elgyqc
elgyqc's Avatar
Much better than the neck of a juice bottle that I pulled off a '97 that I bought:
Lol. Lucky I didn't see that before I made mine, it might have influenced me. My problem being the flexible part options were limited.
I like DIY solutions! Probably some good PCV hose would work better for this application though. It`s also important to keep this tube flexible, as the engine moves quite a bit. I`m afraid your current design is too rigid for that. Another thing to consider is that the tube should not collapse under vacuum.
I will keep thinking about alternatives, I'll look at PVC hose as you suggest. The plan is to change the engine again next year so I will see if my solution holds up or if I have to come up with something else.
There is still some movement possible, the tube is just sitting in the bracket so it can move a bit. Time will tell.
Grant
