Old 10-19-2022, 02:05 PM   #25
Coaster
Coaster's Avatar
Originally Posted by preppyr6 View Post
For anyone looking for a 987 MAF housing adapter sleeve (3.25" OD 3" ID) I found this on eBay that might help. The pvc-welt link wont work for us US folks (AFAIK).
https://www.ebay.com/itm/16mm-200mm-PVC-Inner-Diam-Equal-Water-Supply-Pipe-Fittings-Adapter-Connector-/174808609002
Hope this helps someone. Im in the process of sorting parts for this upgrade now.
Initially, looking for a non-tune solution.
Does the 987 assembly come with a MAF sensor installed? I think that is what I understand.
I assume the 987 MAF and fitting comes off (with the special security bits) and the PVC sleeve slides in to reduce the ID to 3". A hole is needed in the reducer tube, and the 987 MAF and fitting is reinstalled? Assuming the 987 MAF assembly comes with a MAF installed, the connector plugs right in?
Later, I assume I can remove the reducer and push a 986SE tune on a 2003 986 S?
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is online now   Reply With Quote
