Old 10-19-2022, 12:01 PM   #10
john12312
2002 Boxster S
Trunk cable release
Originally Posted by flmont View Post
I believe that under the front bumper cover there is a wire cord you can pull that will manually open it..if you have the manual available I think it shows where its located..Good Luck !
Trunk Lids.pdf
In the attached PDF, item 12 is the cable accessible from the right side wheel well after you remove the liner. If you do this you may want to reroute the cable so you van grab it from the front of the car through the grill.
2002 Boxster S 6 spd manual Arctic Silver
john12312 is online now   Reply With Quote
