Old 10-16-2022, 01:55 PM   #6
JDMsurprise
I think you are getting bad advice. The relay under the dash doesn't lose power on the load side when you remove the key. You need to verify circuit integrity on the trigger side of the under dash relay for signal and ground (separately). 3.5v on the trigger side may be caused by ECM pulsing the relay and delay in DVM (digital volt meter) reading. Don't expect 12v constant here until after the motor starts.
Sent from my SM-G781W using Tapatalk
JDMsurprise is offline   Reply With Quote
