Old 10-15-2022, 02:47 PM   #25
Luckyman01
Took a stab today,
A savvy fiend came by and we took a stab. We focused on the two fuel based relays. The fuel pump one up under the das and the DME one back in the trunk in right side.
To be honest I was barely keeping up and I will ask him to answer any technical questions.
Both relays passed bench test, clicked and functioned as expected.
However when the pump relay was reinstalled, when a voltmeter was used, one pin measured 12 and the other 3.5 on the under the dash relay.
The back one seemed to get inconsistent signals from the magic box, TME, ECM ?
In fact when one turned off the ignition one side continued to show 12 volts when my friend believed it should drop to zero when the key is removed.
Anyhow I am not real technical of a guy. I can source the answer to clarifying questions.
While mu buddy when home and will think about it and come back, he is leaning towards a faulty DME as it seems to be sending incosistand signals to the DME relay in the trunk, I am clueless.
Does anyone know have a wiring diagram for the DME itself?
David
Luckyman01 is online now   Reply With Quote
