Old 10-14-2022, 08:40 PM   #11
ike84
Originally Posted by subieworx View Post
It's only going to be spot on when cruising though in closed loop fueling. Once it enters open loop fueling it will ignore the oxygen sensor for the most part and run programmed values. The primary oxygen sensor is not a wideband sensor and is not used for full time close loop control as I understand it in this car.
This is not correct. This is the entire point of ltft adaptations. My afr at wot is 10.5-12 depending on load and slope.
Sent from my SM-N976V using Tapatalk
