Old 10-11-2022, 04:15 AM   #10
elgyqc
elgyqc's Avatar
The 3.2 engine and 6 speed transmission are now out of the car. When installing the 2.7 I am assuming that I can use the original 2,7 flywheel with the 3.2 clutch disk and pressure plate. Any other parts that must be switched?
The other difference I see is the backup light switch wiring. If I remember correctly on my base boxster the connector is different and I don't see the wire on my 2.7 engine so I suspect that it goes to the cars wiring harness not the engine's.
Grant
