Old 10-07-2022, 06:04 PM   #1
DarkStar
DarkStar's Avatar
Originally Posted by Coaster View Post
Thanks for the update. Do you know if the dot matrix version could be done? They are bi-color (orange and red). Could it be made blue and red?
Yes. It's just a lot of work. If you have any soldering skills you should be able to do it. You need blue replacement LEDs and to desolder/remove the old LEDs. Solder in the new ones. And you'll have to make some kind of diffuser. The dot matrix screen has a orange plastic diffuser so when you do the Blue color it makes it impossible to shine through. So I made it out of white paper. Which I ended up printing a pattern in gray and white to get the pattern I did (LCARS)
DarkStar is offline   Reply With Quote
