Old 10-04-2022, 05:34 AM   #8
subieworx
It's only going to be spot on when cruising though in closed loop fueling. Once it enters open loop fueling it will ignore the oxygen sensor for the most part and run programmed values. The primary oxygen sensor is not a wideband sensor and is not used for full time close loop control as I understand it in this car.
subieworx is offline   Reply With Quote
