Old 10-01-2022, 05:01 PM   #11
elgyqc
elgyqc's Avatar
When the seller of a used car tells you that there is "nothing to do"... don't believe them!
Actually it's not that bad (other than the dead engine) but a fair amount of maintenance is not up to date including the broken console box hinges, the stuck mirror, low speed fans not working, front and rear lid struts that are weak, broken plastic shields underneath... most of the normal stuff when you buy a 22 year old used car.
The engine has been out at some point, there is a mixture of metric and SAE nuts and bolts holding the exhaust on. I assume they did some work that included putting too much sealant on some mating surfaces... and that is what ended up in the oil pickup screen. There are some oil leaks, the engine is encrusted in oil soaked grunge.
The biggest problem at the moment is that the car has been driven in the winter and there is significant corrosion on most of the fittings. Nothing on the body but bolts are rusty, but not eaten away by the rust... it is the hose clamps and smaller fittings that are doubling the time spent in disassembly. Of the 12 bolts on the headers I think 4 came out, 4 broke and 4 will have to be ground or drilled. The engine that is going in has nice stainless studs installed with brass nuts.
On the positive side, the muffler is an aftermarket NHP (looking forward to hearing that) and many of the suspension parts are new.
Grant
