Old 09-25-2022, 12:37 PM   #2
blue62
Originally Posted by pilot4fn View Post
Thanks blue62 for a good info
The car runs real well thru out the rpm range - also at the track.
Reason for this original question is that I'm trying to investigate (and budget) the upcoming winter maintenace work needed (all chain ramps, RMS, IMSB, flywheel, clutch, chain tensioners, etc) or if there is something bigger issues for larger teardown.
I'll continue investigating with more detailed approach.
A few dyno runs would tell you lots about how the engine is performing.
if it had performance issues dyno runs can help you pin them down.
