Old 09-23-2022, 11:06 PM   #17
JDMsurprise
I had the exact same symptoms. Fuel pump relay was not triggered when turning the key to the run position. My problem was bad chassis ground for the circuit. The ground for this circuit is behind the instrument cluster. I believe my nut simply fell off and the eyelets were making intermittent contact.
Sent from my SM-G781W using Tapatalk
JDMsurprise is offline   Reply With Quote
