Old 09-23-2022, 05:30 AM   #1
Quadcammer
Originally Posted by ike84 View Post
You actually will not need to remap the dme, so long as you keep the maf housing the same. The dme cares not the displacement, it just needs accurate measurements of air coming in, so that it can deliver the proper amt of fuel and then have it check out on the exhaust size. If you change your maf housing, however, you will need a new map. PIWIS II is what you'll need - I wrote up a diy on flashing procedure a few years ago.
I don't think that the 6 speed bolts to the 2.7. Someone check me on that, but I'm pretty sure the patterns are different.
Sent from my SM-N976V using Tapatalk
Not necessarily true. The dme can adjust only so much to remove fuel to get the smaller motor to a reasonable a/f, so you may hit correction limits
